Automation Engine Rolling Trace v12 and higher
Article ID: 84639
CA Automic Workload Automation - Automation Engine
Automation Engine v12 introduced memory tracing, therefore there is an additional keyword to set log rotation.
Component: Automation Engine
Rolling trace syntax from v11 and older should not be used in v12 because it will repeatedly switch the Trace type between "FILE" and "MEMORY" whenever the trace turns on and off.
TIME EVENT: EVNT.ROLLING_TRACE_START
EVNT.ROLLING_TRACE_START - Event tab
Check Intervals of:  X minutes
Check: Repeated
EVNT.ROLLING_TRACE_START - Process tab
! Turn On
!Set a TCP/IP=2 and DB=4 trace on the WP
!Turn on tracing for WPs
:SET_UC_SETTING SET_TRACE, &$SYSTEM#, "2400000000000000", "FILE"
!Turn on tracing for single CP - Before # sign is the System name, after # sign is CPxxx where xxx is the CP number
!Example:
:SET_UC_SETTING SET_TRACE, "&$SYSTEM##CP001", "9000000000000000", "FILE"
:SET_UC_SETTING SET_TRACE, "&$SYSTEM##CP002", "9000000000000000", "FILE"
:SET_UC_SETTING SET_TRACE, "&$SYSTEM##CP003", "9000000000000000", "FILE"
!Set a TCP/IP=9 trace on the Agent - <Agent Name> needs to change to reflect actual agent
!Turn on tracing
:SET_UC_SETTING SET_TRACE, "<Agent Name>", "9000000000000000", "FILE"
EVNT.ROLLING_TRACE_START - !Process tab
Note: The !Process in v12.0 can be seen in the Java UI, but in AWI this is the "Event Process."
! Turn off
!Set a DB=4 and TCP/IP=2 trace on the WPs
!Turn off tracing for WPs
:SET_UC_SETTING SET_TRACE, &$SYSTEM#, "0000000000000000", "FILE"
!Turn off tracing for single CP - Before # sign is the System name, after # sign is CPxxx where xxx is the CP number
:SET_UC_SETTING SET_TRACE, "&$SYSTEM##CP001", "0000000000000000", "FILE"
:SET_UC_SETTING SET_TRACE, "&$SYSTEM##CP002", "0000000000000000", "FILE"
:SET_UC_SETTING SET_TRACE, "&$SYSTEM##CP003", "0000000000000000", "FILE"
!Turn off agent tracing
:SET_UC_SETTING SET_TRACE, "<Agent Name>", "0000000000000000", "FILE"
! Turn Back On
!Turn on agent tracing
SCRIPT: SCRI.STOP_ROLLING_TRACE
SCRI.STOP_ROLLING_TRACE - Process tab
! Turn off
