ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
SQL VARA object references are not correctly resolved
Article ID: 84630
CA Automic Workload Automation - Automation Engine
Error Message : N/A
References of VARA.SQLI / VARA.SQL / VARA.SEC_SQLI / VARA.SEC_SQL with format {VARA,KEY,COLUMN} are not resolved correctly. These references return a copy of the SQL statement rather than its result.
Investigation
Here is a simple test scenario :
1. Create a VARA.SQLI object with the statement below:
Upon hitting the "Preview" button it returns the current AE user:
<Please see attached file for image>
2. Create a script object with references to this SQLI in the "Variables & Prompts" tab, like below :
3. The script object's process looks like this :
Results
Expected: Both :PRINT lines should return the same result = output of the SQLI variable = the current AE user's name.
Actual: Variable &TEST1# is correctly resolved, but &TEST2# returns the content of the SQL statement. Here is what the report looks like:
SAA/SUP SELECT OH_Name FROM OH, USR WHERE OH_Idnr=USR_OH_Idnr AND OH_Name LIKE 'SAA%' AND OH_Client = 1980 |
Cause type: Defect Root Cause: A wrong filter condition in a {} expression leads to an invalid return value. Instead of an empty string, the latest used SQL statement is returned.
OS Version: N/A
Update to a fix version listed below or a newer version if available.
Fix Status: In Progress
Fix Version(s): Automation Engine 12.2.0 - Planned release date: 2018-06-19 Automation Engine 12.1.1 - Available Automation Engine 12.0.4 - Available Automation Engine 11.2.7 - Available
