Automation Engine V10.07 libstdc++.so.6: version `GLIBCXX_3.4.5' not found
Article ID: 84440
CA Automic Workload Automation - Automation Engine AUTOMIC WORKLOAD AUTOMATION
Error Message :
Automation Engine xxx libstdc++.so.6: version `GLIBCXX_3.4.5' not found
How you can check the library?
On the command line (unix derivate) execute following command:
strings libstdc++.so.6.0.3 | grep GLIBC
The result could look like this:
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBC_2.3
GLIBC_2.2.5
GLIBCXX_FORCE_NEW
As you can see GLBCXX_3.4.5 is missing
The reason why we use old GCC is that some customers might have old OS versions in place and we could face problems if the libstdc* would not be downwards compatible.
Cause type:
By design
Root Cause: Due to the fact that older GCC is used in AE v10 and v11 for older OS version compatiblity.
OS Version: N/A
Download the library from the web site of the manufacturer of the operating system and copy it into the lib folder of the automic server and utility.
Fix Status: No Fix
Fix Version(s):
N/A
Workaround :
N/A
