After power loss Vertica won’t start.
Article ID: 7993
Updated On: 10-27-2023
CA Infrastructure Management CA Performance Management
Our datacenter lost power and after power was restored, we cannot successfully start Vertica.
CAPM 2.8, 3.x
Many systems (even Linux) are under the control of internal policies.
After a reboot, it is not uncommon for the firewall to enable and start on a Linux server.
This will cause the Vertica inter-node communication to fail and Vertica cannot start.
Check the following log:
catalog/drdata/v_drdata_node000*_catalog/startup.log (your node number will vary).
Look for this message:
  "node" : "v_drdata_node0002",
  "stage" : "Waiting for Cluster Invite",
  "text" : "Invited",
  "timestamp" : "2017-09-07 12:23:46.191"
Verify that the firewall if not running and that all nodes in the Vertica cluster can talk to each other on the network.
