My masking is resulting in issues with inconsistent results between FDM Oracle and Mainframe DB2. The resulting mask from FDM does not match the same input data's masking from a DB2 Mainframe masking. The RL_RN code is rendered as two different values, thus producing two different masking results from the same input and same seedlist.
Masking Names/Addresses in Oracle and DB2 results in different values. The RL_RN hashcode is different. How does the TDM MF masking program mask the DB2 names RL_RN = 2027 as oppose to 2765? Why not use the same FDM RL_RN value?
TDM FDM masking function HASHLOV hashes on column RL_RN = 2765 (mask to NAME = BRIAN FRIEND)
TDM MF masking function HASHLOV hashes on column RL_RN = 2027 (mask to NAME = KAREN COVINO)
Note: We are using DB2 Seedlists to mask consistently for both Oracle and DB2
The issue is in the setup.
First, in the PARMCD input to the mainframe masking program, set -
HASHTYPE=JAVA
In addition, if the column containing the ssn is a string type which may have leading/trailing blanks set -
TRIMMEDHASHLOV=Y
It is important to note that the HASHTYPE=JAVA on the Mainframe parameter side is what ultimately resolved this issue.
