When trying to connect our DB2 database in Fast Data Masker, I am seeing the following error message:
Error: Class not found com.ibm.db2.jcc.DB2driver
The DB2 jar files are missing from the FDM lib directory folder.
When using DB2 on z/OS with FDM, copy the db2jcc4.jar, db2jcc4_license_cu.jar, db2jcc4_license_cisuz.jar, and the common.jar files provided by the vendor and paste them into the C:\Program Files\Grid-Tools\FastDataMasker\lib folder.
This is noted here: https://docops.ca.com/ca-test-data-manager/4-4/en/provisioning-test-data/mask-production-data/fast-data-masker-system-requirements
If you experience any further issues, please open a support case by going to https://www.ca.com/us/services-support/ca-support/contact-support.html.
