As an alternative to the SMPE method of applying the license key with CYBALI39 for CA Alchemist, you can use AMASPZAP to apply the zap supplied by CA Licensing:
//* ZAP A LOAD MODULE
//STEP1 EXEC PGM=AMASPZAP
//SYSPRINT DD SYSOUT=X
//SYSLIB DD DISP=SHR,DSN=....SSALLINK
//SYSIN DD *
NAME ZDEDDB ZDEDDB
REP 0100 aaaaaaaa,bbbbbbbb,cccccccc,dddddddd
REP 0110 eeeeeeee
If the updates are not successful, follow the instructions provided by the utility messages.
For example:
AMA120I ZDEDDB NO IDR SPACE - RE-LINK
AMA127I UPDATES INHIBITED (NO OVERRIDE) Based on AMA127I message recommendations (see below), reran zap successfully with the IGNIDRFULL parm.
AMA120I mod NO IDR SPACE -- RE-LINK
Explanation - A REP operation was to be performed on a module, but SPZAP found that no space is available in the IDR for maintenance information.
System action - Message will be followed by either AMA127I or AMA128I.
System programmer response - The indicated module must be reprocessed by the linkage editor so that the module will contain an additional IDR; then rerun the SPZAP job.
Explanation - This message is issued after message AMA120I to indicate inhibition of updates to the module because all IDR entries for that module have been filled.
System action - Processing continues except for rejection of REP and IDR statements for this module.
System programmer response - Re-link edit the module to create a new IDR, or rerun the job with IGNIDRFULL option specified.
