ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Single Sign On Problems between V6 and R12
Article ID: 7642
CA Single Sign On Secure Proxy Server (SiteMinder) CA Single Sign On SOA Security Manager (SiteMinder) CA Single Sign-On
Failed SSO between to separate environments (disparate policy stores).  Looking for what needs to be in place in order to achieve SSO when clients navigate between webserver in V6 and R12
SSO fails when navigate between environments because the session ticket is not the same.  SMSESSION cookie was able to be decoded (Agent keys were the same), however when the agent sent the session spec to the policy server it was not able to read session spec, this is logged as “invalid key in use” in the smaccess log and trace log of the policy server.
Two environments where the policy server point to different policy stores. Store 1 Oracle LDAP and Store 1 CA Directory 12 SP18
Session ticket is unreadable v6 and r12 (V6 will treat as NULL, R12 will fail to valid sessions
Option to move past this issue
Reset the session ticket in both environment to a known value (NOTE this will force all current logged in session to be rechallenged
This is done in the adminUI see example:
<Please see attached file for image>
src="/servlet/servlet.FileDownload?file=0150c000004AKO9AAO" alt="session-key.png" width="915" height="513">
Name of the UserDir Object in Admin UI must be defined with the same name in both policy stores; also the authenticated user DN must also be the same
OR
AuthValidation functionality can be used if (a) is not possible
Common errors to look for when SSO fails:
  • Failed to decrypted (SESSION keys is different)
ERROR WebAgent Trace:
[DecodeCookie][WARNING: Failed to decrypt SMSESSION= cookie.]
  • Invalid key in use
SESSION Ticket is not the same or “custom agent” created SMSESSION cookie which is resolved by setting ACP parameter AcceptTPCookie top yes
Error Policy Server trace Az [** Status: Not Authorized. Invalid key in use]
  • User directory name problem
User “A” is not Authorized in second environment - User directory name problem
Error Policy Server:
[00:15:48][** Status: Not Validated. Failed to resolve user directory 'Us
erStore_Authentication', '0e-3dffab22-c0db-0028-0000-165100001651']
1558700001743000007642_sktwi1f5rjvs16ow1.png get_app
