Sites upgrading, may need to reset various options since the upgrade process will reset options to default values. Use the CA Ideal command PRINT SESSION OPTIONS to save a list of option values before the upgrade. Optionally, create a MEMBER to EXECUTE after the completed upgrade containing the commands to reset site options.
All published APARs for CA Ideal 15.0 should be applied after the SMP/E install and before executing the configuration steps. Please refer to http://support.ca.com to download 15.0 solutions.
