After a IPL, the CA 7 Web Client will not start. You see the following message in the startup log:
SEVERE: StandardServer.await: create[localhost:8005]:
Throwable occurred: java.net.BindException: EDC8116I Address not available.
Apache Tomcat is unable to bind to the shutdown port.
Disable the Apache Tomcat shutdown port by doing the following:
Go to the server.xml file located in: tomcat directory where you installed the web client. The catalina_home variable point you to this directory and disable the
shutdown port by changing the following:
change:
--><Server port="8005" shutdown="SHUTDOWN">
to
--><Server port="-1" shutdown="SHUTDOWN">
After you change port to -1, restart web client and it should start.
