Problems building Aion apps related to licensing files
Article ID: 65911
Aion Business Rules Expert
You have problems with building Aion apps, like a coredump. The problem can be traced back to the licensing files in /ca_lic. What is the easiest way to correct this problem?
You will have to obtain an updated copy of the licensing software from the support portal, assuming your userid has access authority or you can open an issue with Global Support.
STEP 1: INSTRUCTIONS - For all platforms
  1. Make a backup copy of your existing CA.OLF file located in the CA_LIC directory of the machine(s) in question. Name the backup OLDOLF.BKP.
  2. Copy the contents of this <license.txt> file and append it to the bottom of the original CA.OLF file on the machine that is experiencing the licensing error.
  3. Save the newly updated CA.OLF file.
  4. The change will take effect immediately (it is not necessary to reboot your machine or recycle the licensed product).
  5. Contact your Technical support contact if you need assistance with these steps.
STEP 2: INSTRUCTIONS - For AIX 5.1 sp3
  1. Download the file lic98aix.tar.z into a temporary directory called /TEMP (note, it should be '/' and not '\' which is for Windows).
  2. Stop all Broadcom Enterprise products on your machine.
  3. Go to the /TEMP directory and uncompress the file: uncompress lic98<platform>.tar.z
  4. Backup all the files under /ca_lic directory.
  5. Copy the uncompressed file from Step 3 to /ca_lic directory.
  6. Untar the file: tar xvf lic98<platform>.tar
  7. Run the 'install' script (either 'install' or as './install')
  8. Copy the ca.olf file from the backup you made in Step 4 to the /ca_lic directory. Make sure it is owned by 'root' with file permissions of at least 644.
