When applying Endevor maintenance using the SCM80APM job, getting a bunch of GIM30209E ** APPLY PROCESSING FAILED errors
Article ID: 6439
Endevor Endevor Natural Integration Endevor - ECLIPSE Plugin Endevor - Enterprise Workbench
When applying Endevor maintenance using the SCM80APM job, getting a bunch of GIM30209E ** APPLY PROCESSING FAILED  errors:
GIM30209E ** APPLY PROCESSING FAILED FOR SYSMOD RO91535. REQUIRED SYSMODS FAILED OR WERE MISSING.
GIM35951I    PREREQUISITE SYSMOD RO91813 WAS MISSING. SYSMOD RO94676 WOULD HAVE SUPERSEDED RO91813, BUT HAS FAILED.
GIM30209E ** APPLY PROCESSING FAILED FOR SYSMOD RO92730. REQUIRED SYSMODS FAILED OR WERE MISSING.
GIM35907I    PREREQUISITE SYSMOD RO92892 FAILED.
The reason the PTF identified in the GIM30209E error message failed to apply is explained in the messages that follow.
A GIM35951I message identifies the pre-req PTF that has not been applied and that it would have been superseded by another PTF but that PTF failed to apply.
A GIM35907I message identifies a pre-req that failed to apply.
A GIM35904I message identifies a pre-req that is missing.
Download all the PREREQUISITE SYSMOD PTFs identified in the GIM35951I and GIM35904I messages.
Note: Even the PTFs identified in the GIM35951I messages that have been superseded by another PTF need to be downloaded and applied.
