Numeric Range Filter Problem
Article ID: 59125
Updated On: 07-03-2023
Clarity PPM SaaS Clarity PPM On Premise
When a filter value is entered for Priority (e.g. from 1 to 35) in Project List page and we click on "Filter" everything works fine the first time. But then the system changes the value in the priority filter field and includes decimals to the value entered (ex: 1.00 or 35.00). If we click on "Filter" again for the second time an empty list is presented (although the filter criteria did not change). Clarity is filtering for the exact decimal value like 1.00 whereas the Priority is 1.
Steps to Reproduce:
  1. Login to Clarity and navigate to Project list view
  2. Configure the 'Priority' attribute to be in the Filter Selected layout
  3. Enter a value for priority (ex:1 or 35) and click 'Filter' button - everything works fine the first time, then the system changes the values in the priority filter field and includes decimals to the value entered (ex: 1.00 or 35.00)
  4. Now click 'Filter' a second time - an empty list is presented (although the filter criteria do not change) ; it doesn't return any data since the priority doesn't have decimal values
Expected Result: The system shouldn't change value from integer to decimal (eg. 1 to 1.00)
Actual Result: The system changes value from integer to decimal (eg. 1 to 1.00)
Release: All supported clarity version
This issue is fixed in latest release
