This Knowledge Document explains the ALIMIT parameter setting when using the virtual tape systems.
Virtual tape systems are widely used for archiving and data warehousing applications. The use of this technology has an impact on the archival function in both JMR and SMR.
Both JMR and SMR use the ALIMIT parameter to specify the number of multiple datasets that will reside on a single archive tape.
When using physical tape volumes, optimum efficiency is achieved by stacking multiple ARCHIVE datasets on a single-tape volume. Set the value of the ALIMIT parameter between 10 and 20 files.
When converting to one of the currently available virtual tape systems, the ALIMIT parameter value must be set to 1. Setting this parameter to 1 is critical for two reasons:
