Using CleverPath Forest and Trees to programmatically configure File Permissions when publishing to CleverPath Portal
Article ID: 55910
Updated On: 11-01-2023
Cleverpath Reporter
When publishing a file to CleverPath Portal there are a number of properties that may be configured which determine how that file will be handled. This document supplements the current CleverPath Forest and Trees 7.0 Help Topics, specifying definitions for a number of properties, including example code demonstrating the process of programmatically publishing a Microsoft Excel file to CleverPath Portal.
Release:
Component: FTS
Object Properties
For any given object, the Object Wizard may be used to list properties and methods for that object. For publishing to the Portal, the particular object type of interest is 'PortalPublisher'.
To use the Object Wizard, a variable of the appropriate object type must be declared, either with a Dim statement or in the Tools > Variables dialog. Within the Edit Formula window, position the cursor after the Dim statement (if declared locally), select the Object Wizard button (the first one in the Edit Formula window toolbar), then select the desired object type and the variable representing an instance of that object type. On the next wizard page will be listed the methods and properties supported by that object, and a short description of the methods and their parameters (if any).
Portal Publisher properties
To demonstrate the usage of Portal Publisher properties an example FTV may be downloaded. The example provides code that will login to the Portal, set Portal permissions on a Microsoft Excel file, and publish the Microsoft Excel file to the CleverPath Portal.
The example portal_pub.ftv requires some configuration to function within a given environment. See the formula script for view 'publish'. The individual line of script requiring configuration are marked 'Change'.
Portal Parameters
Modify the view 'publish' formula script to configure the following Portal parameters
Change 1 - <portal Username>
Change 2 - <portal Server>
Change 3 - <port>
Change 4 - <password>
This will allow the application to login to the Portal
Publisher Parameters
Modify the view 'publish' formula script to configure the following Publisher parameters
Change 5 - Determine the object key for the parent folder in portal where you want to publish the file. Each folder in portal has an object key that can be found by logging in to the portal.
Eg) pp.Parent := 103
Change 6 - Specify the local path for the source file to be published (note the trailing slash)
Eg) sourceFilePath := 'C:\Documents and Settings\username\My Documents\My Excel\'
Change 7 - Specify the filename for source file to be published
Eg) sourceFileName := 'a.xls'
Change 8 - Specify the Title for the published content.
pp.Title := 'test excel' // optional--could duplicate file name
Change 9 - The (MIME) ContentType must be set to the appropriate value for the type of file being published. A table of the standard content types defined on CleverPath Portal is included at the end of this document. In the example this parameter is set for Excel.
Eg) pp.ContentType := 'application/vnd.ms-excel'
Change 10 - Change the GroupOwner to the object key of the Portal Workgroup that the content will belong. This can be found by logging into the Portal.
Eg) pp.GroupOwner := 72
Change 11 - Set the View/Modify Permissions for the published file. A table containing the available View/Modify permissions on CleverPath Portal is included at the end of this document.
Eg) pp.Permissions := 'GroupModify' // (or numeric equivalent: 504)
Change 12 - Set the Userowner for the published file to the object key of the Portal User. The object id for a Portal User can be found by logging into the Portal, or in the example ftv, this is retrieved automatically in View 'ps' through a portal statistics view.
Eg) pp.UserOwner := 22 // object key obtained from portal
Viewing published content
When the example ftv has been configured correctly, calculating the view 'publish' should result in the specified file being published to the Portal with the given permissions.
The example provided is intended to illustrate how permissions and other properties may be set when publishing content. It is likely that any programmatic publishing implementation will require additional design and coding dependent on the specific requirement and environment.
Sample code in this document is:
Copyright ? 2004 Computer Associates International, Inc. All rights reserved.
You have a royalty-free right to use, modify, reproduce, and distribute this sample code in any way you find useful, if you agree that Computer Associates has no warranty, obligations, or liability for any sample code.
Default ContentType parameters for CleverPath Portal
File Extension Set ContentType to this value
aif audio/x-aiff
aifc audio/x-aiff
aiff audio/x-aiff
art x-jg
asf video/x-ms-asf
asx video/x-ms-asf
au audio/basic
avi video/x-msvideo
bmp image/bmp
c++ text/plain
c text/plain
cc text/plain
class application/x-java
cpp text/plain
doc application/msword
dtd text/plain
exe application/octet-stream
gif image/gif
h++ text/plain
h text/plain
htm text/html
html text/html
ivi application/vision
java text/plain
jfif image/pjpeg
jpe image/jpeg
jpeg image/jpeg
jpg image/jpeg
m1v video/mpg
mov video/quicktime
mp2 video/mpg
mpa video/mpg
mpe video/mpg
mpeg video/mpg
mpg video/mpg
pac application/x-ns-proxy-autoconfig
pdf application/pdf
pl text/plain
png image/png
pot application/vnd.ms-powerpoint
ppa application/vnd.ms-powerpoint
pps application/vnd.ms-powerpoint
ppt application/vnd.ms-powerpoint
ps application/postscript
pwz application/vnd.ms-powerpoint
qt video/quicktime
ra audio/x-pn-realaudio
ram audio/x-pn-realaudio
rtf text/richtext
sh application/x-shar
snd audio/basic
spl application/futuresplash
swf application/futuresplash
tar application/x-tar
text text/plain
tif image/tiff
tiff image/tiff
txt text/plain
uu application/octet-stream
vis application/vision-compressed
wav audio/x-wav
wax audio/x-ms-wax
wbmp image/vnd.wap.wbmp
wm video/x-ms-wm
wma audio/x-ms-wma
wmd application/x-ms-wmd
wml text/vnd.wap.wml
wmls text/vnd.wap.wmlscript
wmv video/x-ms-wmv
wmx video/x-ms-wmx
wmz application/x-ms-wmz
wrl x-world/x-vrml
wvx video/x-ms-wvx
xls application/vnd.ms-excel
xml text/xml
zip application/x-zip-compressed
View/Modify Permissions for CleverPath Portal
Portal View
Permissions
Modify Keyword
Permissions Property Setting Code Number
Public Public PublicModify
511
Public WorkgroupPublicView GroupModify
509
Public Owner PublicView
493
Workgroup Workgroup GroupModify
504
Workgroup Owner GroupView
488
Owner Owner PersonalModify
448
