Reference guide to the settings that prorep.prf and proserv.prf usage
Article ID: 55754
Cleverpath Reporter
Is there any reference guide to the settings that prorep.prf and proserv.prf can use?
Reporter-Developer Client
Yes, under the DOC directory of the Cleverpath Report install dir in the file prorep.hlp. Open the file, and "drill down"
Under the Contents tab, select: Reference Guide (hit the open button) Preference Options Preference Files Report Builder
Report Server
