Having an AMF Dataset: XXXX.YYYY.ZZZZ
.***' and trying to copy every Friday the 5 most current files from this DSN using TDYNCOPY with the following JCL:
// JOB TAPECOP *** COPY TAPE TO TAPE ***
// ASSGN SYSLST,03E
// UPSI 11000000
* FRIDAY
// TLBL UIN,'XXXX.YYYY.ZZZZ.***',,,,,,24
* TUERSDAY
// TLBL UIN,'
XXXX.YYYY.ZZZZ
.***',,,,,1,24* WEDNESDAY
// TLBL UIN,'
XXXX.YYYY.ZZZZ
.***',,,,,2,24* THUSDAY
// TLBL UIN,'
XXXX.YYYY.ZZZZ
.***',,,,,3,24* MONDAY
// TLBL UIN,'
XXXX.YYYY.ZZZZ
.***',,,,,4,// TLBL UOUT,'
XXXX.YYYY.ZZZZ
.COPY.***',,,,,,24// TLBL UOUT,'
XXXX.YYYY.ZZZZ
XXXX.YYYY.ZZZZ
XXXX.YYYY.ZZZZ
XXXX.YYYY.ZZZZ
.COPY.***',,,,,,2// EXEC TDYNCOPY
will always result in:
F3 0003 CADT007I ****** LABEL UOUT SYS005=B02 506065 1
XXXX.YYYY.ZZZZ
.COPY.001*F3 0003 CADT509I BLOCK COUNT=0116210 INPUT
F3 0003 CADT510I BLOCK COUNT=0116210 OUTPUT
F3 0003 CADT031I *CLOSED* UOUT SYS005=B02 506065
XXXX.YYYY.ZZZZ
.COPYBLK=116210
F3 0003 CADT004I MOUNT VOLUME 506135 DSN=
XXXX.YYYY.ZZZZ
.015 SYS004MODE=08MH JOB=TAPECOP
F3 0003 CADT002D *NOT LD PNT* SYS004=B01
F3-0003
3 rewind
F3 0003 CADT032I ASSIGNED UIN SYS004=B01 506135 1
XXXX.YYYY.ZZZZ
.015F3 0003 CADT023I ****** DSN '
XXXX.YYYY.ZZZZ
.COPY.002' FILE NO. 2 BEICREATED ON TAPE 506065 B02
XXXX.YYYY.ZZZZ
.COPYBLK=116210
XXXX.YYYY.ZZZZ
.014 SYS004MODE=08MH JOB=TAPECOP
F3-0003
3 rewind
and so on ... and so on ...
DYNCOPY has been already added to the DTLUBEX macro ...
To avoid this Problem (CADT002D *NOT LD PNT*) you need to run TDYNCOPY for AMF Volumes in reversed order (oldest Version at the begin , newest Version as the last one) to honor D/T processing of LOCATE BLOCK.
