How to code REXX conditional job flow with only 1 procedure in ESP
Article ID: 55166
Updated On: 07-09-2024
ESP Workload Automation
Objective: Release a job if it completes with  RC=0 or if a job completed with RC=1
Example: Job B releases jobs C and D (if B completed with a RC=0) OR release jobs E and F (if B finished with a RC=1)
Insert a TASK (after job B) to loop through all jobs 'B' on the CSF, using JOBONCSF, and check the return code of the last job B and bypass the correct SUBAPPL.
Make sure you complete the task as well.
Note: If there are a lot of jobs in CSF then REXX will look at EACH "B" listed to find out the correct generation.
APPL APPL1
JOB A
  RUN DAILY
  RELEASE B
END JOB
JOB B
  RUN DAILY
  RELEASE CHECK.RC
ENDJOB
JOB CHECK.RC TASK
  RUN DAILY
  REXXON
    J = JOBONCSF('B','X')
    DO I = 1 TO J
      IF XAPPLG.I = CLANGVAR('%ESPAPGEN') THEN
        DO
          IF XCONDCODE.I = 1 THEN
            DO
              "ESPNOMSG AJ JOBB_RC0 BYPASS APPL(%ESPAPPL..0)"
              "ESPNOMSG AJ CHECK.RC COMPLETE APPL(%ESPAPPL..0)"
            END
          ELSE
            DO
              "ESPNOMSG AJ JOBB_RC1 BYPASS APPL(%ESPAPPL..0)"
            END
        END
    END
  REXXOFF
  RELEASE (C,E)
ENDJOB
JOB C
  SUBAPPL JOBB_RC0
  RUN DAILY
  RELEASE (D)
ENDJOB
JOB D
  SUBAPPL JOBB_RC0
  RUN DAILY
ENDJOB
JOB E
  SUBAPPL JOBB_RC1
  RUN DAILY
  RELEASE (F)
ENDJOB
JOB F
  SUBAPPL JOBB_RC1
  RUN DAILY
ENDJOB
