Does Automation Point create and populate the SQL Server Notification Manager Database or does that have to be done manually?
Article ID: 54195
Automation Point
Description:
I need to know if Automation Point detects a current database or does it prompt you for creating or updating an existing one.
Solution:
When you install AP, it searches for a SQL Server database. If it detects one, it will prompt you to create and populate the database.
NOTE: If you install a SQL Server after you install AP, you will have to manually create and populate the database.
Release:
Component: ATMXC
