Interface with IBM Robot System gives Message: CADT899E IBM MOUNT REQUEST FAILED, RC = 108 REASON CODE 3344
Article ID: 52901
Updated On: 10-18-2024
Dynam for VSE Dynam VSE Option
CA Dynam/T Tape Management for z/VM or CA Dynam/T Tape Management for z/VSE DYNVM Extension with Interface to IBM Robot gives error Message:
CADT008I (IUCV:VSE250,F6) MOUNT SCRATCH SYS000 SYS000
What does Reason Code 3344 mean?
Release:
Component: DYNTVM
The CADT899E with Reason Code = 3344 means: there are no more scratch volumes in the requested scratch category available in the IBM robot.
To solve this, run Program DYNAMCMS TDYNIBMon a machine that has the authority to issue DFSMSRM commands.
