Auto-suggest does not work when "Order By" or "Group By" clauses are used in Dynamic Query Lookups
Article ID: 5243
Clarity PPM SaaS Clarity PPM On Premise
When a dynamic query contains an "Order By" or "Group By" clause, the auto-suggest functionality does not work.
Steps to Reproduce:
1. Create a dynamic lookup, with a code such as the below:
select
@select:id:[email protected]
@select:name:[email protected]
from inv_investments
where @[email protected]
order by name
2. Couple this lookup to an attribute on an object. Display this attribute in the Layout:Edit view
3. Navigate to the appropriate Layout:Edit view, and browse for a value on this lookup field. Copy this value
4. Refresh the page and paste the value copied in step 3 in the lookup field.
Expected Result: The lookup field matches and provides suggestions
Actual Result: The lookup field does not provide suggestions
CA PPM all supported versions
"Order By" clause is not to be used in Dynamic Lookups. The UI of Dynamic Lookups provisions for ordering a single column, and that is the design right now. As for the "Group By" clause, it is to be used with "Having" clause - with a syntax such as @[email protected] This prerequisite is documented here.
For situations that require the "Order By" clause, the UI provides a way to sort a column.
