Description:
CA Detector Standard Activity commit and abort counts are not displayed within a SQL query of Detector archive tables even though they appear in the Detector datastore. Why is this the case?
Solution:
In the CA Detector datastore the commit and abort counts appear only on the Plan or Key Summary screens.
Below is an example of the counts displayed by Plan:
R11.05 > --------- DETECTOR Planname Summary Display -------- 09/12/03 08:19 DB2 SSID ==> DB21 View By ==> P * -Plan G -Prog S -SQL Q -DSQL F -Prof K -Key Total/Avg ==> PLANNAME COMMIT ABORT ---------- -------- ------ _ PLAN1 17 3 _ PLAN2 12 8 _ PLAN3 1 9 _ PLAN4 0 11
Even when the counts are displayed by Key, they have previously been computed by Plan, as the following screens show.
If USER1 is selected:
R11.05 > --------- DETECTOR Key Summary Display -------- 09/12/03 08:19 DB2 SSID ==> DB21 View By ==> K P -Plan G -Prog S -SQL Q -DSQL F -Prof * -Key Total/Avg ==> KEY COMMIT ABORT SQL ------------ -------- ------ --------- s USER1 30 31 714553 _ USER2 541 10 11893 _ USER3 55 107 27489
..Key Commit and Abort total counts that were displayed on the previous screen were computed using the counts below:
R11.05 > ----------- DETECTOR Key Planname Display ---------- 09/12/03 08:51 Userid ==> USER1 DB2 SSID ===> DB21 PLANNAME COMMIT ABORT ---------- -------- ------ _ PLAN1 17 3 _ PLAN2 12 8 _ PLAN3 1 9 _ PLAN4 0 11
Similarly, on the Detector Standard Activity archive table, the rows with a RECTYPE equal to 'PLAN' contain the commit & abort counts. The rows for Plans 1 through 4 would appear as follows in an Interactive SQL report:
RECTYPE PLANNAME PROGRAM COMMIT ABORT PLAN PLAN1 17 3 PLAN PLAN2 12 8 PLAN PLAN3 1 9 PLAN PLAN4 0 11
The remaining record types do not contain these counts. The remaining rows for PLAN1 along with their record types appear below:
RECTYPE PLANNAME PROGRAM COMMIT ABORT PKGP PLAN1 PLAN1 0 0 PGM PLAN1 PLAN1 0 0 STMT PLAN1 PLAN1 0 0
..so, RECTYPE PLAN must be used to retrieve the commit and abort counts.
