Description:
The NSQL construction SUM(DECODE(R.ID,4,0,NVL(R.ID,0)/ .. causes Error 500 on a portlet when used as a power filter.
Steps to Reproduce:
SELECT @SELECT:DIM:USER_DEF:IMPLIED:RESOURCE:R.FULL_NAME:[email protected], @SELECT:DIM_PROP:USER_DEF:IMPLIED:RESOURCE:MR.FULL_NAME:[email protected], @SELECT:METRIC:USER_DEF:IMPLIED:SUM(DECODE(R.ID,4,0,NVL(R.ID,0)/(CASE WHEN R.ID <> 0 THEN 1 ELSE 3600 END))):[email protected] FROM INV_INVESTMENTS I, SRM_RESOURCES R, SRM_RESOURCES MR, CMN_SEC_USERS U WHERE I.CREATED_BY = U.ID AND U.ID = R.USER_ID AND R.MANAGER_ID = MR.USER_ID AND @[email protected] GROUP BY R.FULL_NAME, MR.FULL_NAME HAVING @[email protected]
Expected: The user should be able to filter according to AGG attribute.
Actual: Error 500 - Internal Server Error.
Error from app-niku.log file:
Caused by: java.sql.SQLException: [CA Clarity][Oracle JDBC Driver][Oracle]ORA-00934: group function is not allowed here
Solution:
This issue has been documented as CLRT-43004 and is assigned to development for review.
Keywords: CLARITYKB, error, power, filter, NSQL, clarity8open, clarity12open.
