URL setting for connection using TLS certificate verification
Article ID: 51032
Updated On: 10-27-2023
ACF2 ACF2 - DB2 Option ACF2 for zVM ACF2 - z/OS ACF2 - MISC 24X7 High-Availability Manager for DB2 for z/OS Batch Processor Compile QQF Data Compressor for DB2 for z/OS CA Unicenter NSM RC/Update for DB2 for z/OS DB2 TOOLS- DATABASE MISC Top Secret Top Secret - LDAP
Documentation states:
port (Optional). Specifies the TCP/IP port that the CA LDAP Server is using.
Default: 389.
What is suggested port for SSL connection using TLScertificate verification
Release:
Component: TSSLDP
URL specified as ldaps://:636 is recommended port number, however it can be any port number as long as it is not already being used.
TLSKeyringName and TLSCertificateLabel are required to be set in slapd.conf file to secure the connection with SSL.
Please refer to the CA LDAP documentation for more details about all the configuration options for the slapd.conf file.
