Info Transport GCC configuration problem on AIX
Article ID: 49940
RC Compare for DB2 for z/OS 24X7 High-Availability Manager for DB2 for z/OS Batch Processor Compile QQF Data Compressor for DB2 for z/OS CA Unicenter NSM RC/Update for DB2 for z/OS DB2 TOOLS- DATABASE MISC Database Analyzer for DB2 for z/OS Fast Unload for DB2 for z/OS Fast Check for DB2 for z/OS Fast Index for DB2 for z/OS Rapid Reorg for DB2 for z/OS
Description:
Trying to configure CA InfoTransport on an AIX platform using gcc for the C-Compiler option encounters the gcc error stating the command is invalid.
Solution:
To use the gcc compiler to create the libdbar.so shared object on AIX, save a copy and make the following 3 changes to setlib.sh:
line    61    currently reads "RLDFLAGS="-G"     change to                                     RLDFLAGS="-Xlinker -bsvr4 -Xlinker -dy -Xlinker -berok -Xlinker -brtl -Xlinker -bnortllib -Xlinker -bnoentry -Xlinker -bM:SRE"                                                            Line    63     currently reads DYNOPT="-bdynamic"                            change to        DYNOPT=" "        Line     296    currently reads LOCALLIB="-L . -ldbsql"                      change to        LOCALIB="libdbsql.so"
Run create_dblib.sh from the install directory.
Release:
Component: PIR
