Description:
In Clarity version 13, the end-user now has the ability to perform inline editing. We are seeing some problems with this functionality.
Some of the symptoms observed include: when in the editing mode, the numbers that come up on the cells are different from what are shown prior to clicking on the cells; or if we double click into a cell and enter a number it is not saved in this cell, it is saved in another cell; data that was entered using a single click on a cell directly below a cell populated using a double-click 'jumps' up one line.
Steps to Reproduce:
Using a double-click in a cell causes problems. This issue applies to any in-line editing grid view.
Example (on Project List View in-line editing)
In this example the cells were blank before making any changes
Row 1, single click (value=5)
Row 2, double-click (10)
Row 3, single click (20)
Row 4, double click (30)
Row 5, single click (40)
Row 6, double-click (50)
Row 7, single click (60)
<Please see attached file for image>
Click 'Save' button. Values on the rows with single click, jumps up to rows with double-click
Row 1 = 5
Row 2 = 20
Row 3 = blank
Row 4 = 40
Row 5 = blank
Row 6 = 60
Row 7 = 0
Expected Result: The entry should be saved in the expected place.
Actual Result: The entry is not saved in the expected place. Since the cells were blank before entry, some cells are not updated and the value that is expected is in a different cell.
Solution:
WORKAROUND:
Do not use double-click to edit a cell.
STATUS/RESOLUTION:
This issue is documented as CLRT-66852
Resolved in Clarity 13.0.1 Generic Patch. Reference TEC572268
Resolved in Clarity 13.1.0
Keywords: CLARITYKB, CLRT-66852, CLRT-67659, CLRT-68134, clarity13resolved, clarity1310resolved, in-line, grid portlet inline editing display wrong value.
Release: ESPCLA99000-13.1-Clarity-Extended Support Plus
Component:
