Problem with Webviewer connection
Article ID: 4905
OM Deliver OM View
CA Web Viewer users may find themselves unable to log in and use the application because the CA DRAS STC is blocked / unresponsive after ENF restart / recycle.
z/OS
CA ENF recycle lost the CA DRAS registration.
1) F ENF,CCI(CLEARALL)
2) RESTART of ENF STC
3) RESTART of CADRAS STC
Afterward, Web Viewer connections should be functional.
Recycling DRAS is usually the key. When a DRAS task starts, it "registers" itself with CCI (which runs under ENF). When ENF is recycled (which should also recycle CCI and all CCI sub-tasks), the DRAS "registration" might get lost. Recycling DRAS will cause it to re-register.
Going forward, if ENF is recycled (not part of a normal IPL) then the DRAS task should be recycled as well, AFTER ENF and CCI are back up.
