Problem with JOBNAME Logical Group and Threshold Triggering
Article ID: 46510
SYSVIEW Performance Management WatchTower WatchTower Platform
I am trying to use logical groups in CICS threshold definitions, but having trouble using type JOBNAME. I have the following definitions in the GROUPS parmlib member:
DEFINE CICSM
TYPE JOBNAME
DESC 'TEST lpar CICS Regions '
MEMBER CICSM1
MEMBER CICSM2
DEFINE MXXXXX TYPE CICSTRAN DESC 'Test out GROUP function '
INSTANCE =
MEMBER SSCC
MEMBER SSCD
The following threshold definition coded in the CTHRESH member does not trigger:
DEFINE LIFETIME JOBNAME >CICSM TRAN >MXXXXX RSCE = LIMIT 30.000 ....
 I also have this rule defined that is triggered:
 DEFINE LIFETIME JOBNAME CICSM* TRAN = RSCE = LIMIT 600.000 ...
Why doesn't the rule defined for the Group CICSM (LIFETIME JOBNAME >CICSM TRAN >MXXXXX RSCE = LIMIT 30.000 ...)  trigger?
SYSVIEW R16.0 and prior releases
First of all, Type CICSPLEX, not JOBNAME,  need to be used creating a logical group for " lpar CICS Regions"  (in this case Group CICSM).
So the definition within  the  GROUPS parmlib member needs to be changed to:
DEFINE CICSM
TYPE CICSPLEX
MEMBER CICSM1
MEMBER CICSM2
Then when viewing the definitions online, we can better understand how the Threshold process searches threshold definitions and finds the best match on a rule.  All threshold definitions for the specific metric or variable name will be processed. The last match in the list "wins". The generic threshold ( DEFINE LIFETIME JOBNAME CICSM* TRAN = RSCE = ) wins over the process to find the best match for a transaction defined in group MXXXXX running in any of the CICS regions included in the CICSM group.
See Topics : Exception definition best match rules    (Type TOPICS in SYSVIEW to reference)
See HELP panel for CTHRESH command
