I get the following error in the baseline_engine log:
com.nimsoft.nimbus.NimClientSession(0.0.0.0/0.0.0.0:62526-/x.x.x.:48000): Connection has been shutdown: SSLHandshakeException: No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
Probes baseline_engine and prediction_engine won’t start, showing a red status.
UIM 8.x os later
When deploying ppm to a hub configured in SSL ONLY mode, baseline_engine and prediction_engine won’t start because of the SSL setting.
Workaround:
- This problem has been resolved in certain environments by executing the following procedure:
1. Navigate to nimsoft/jre/<jre.version>/lib/security on the hub where you have SSL ONLY Mode enabled, and where you deployed ppm. It should look something like C:\Program Files (x86)\Nimsoft\jre\jre7\lib\security.
2. In that directory, open up the java.security file in a text editor.
3. Under the heading:
# Algorithm restrictions for Secure Socket Layer/Transport Layer Security # (SSL/TLS) processing
Check if you see an entry that looks like the following:
jdk.tls.disabledAlgorithms=SSLv3, which does not have a '#' in front of it (thus being uncommented).
If that’s the case, comment the mentioned line (adding a ‘#’ as the first character) and restart the system.
After this change, the line should be read as:
#jdk.tls.disabledAlgorithms=SSLv3
As always, please contact Broadcom support for CA UIM if you have further questions.
