An outage may occur where an NSX Edge virtual machine loses network connectivity to its default gateway , causing NSX Manager to display the following error:
MPA Connectivity Down
VMware vSphere ESXi 8.x
ESXi relies on physical network interface card (pNIC) hardware and firmware interrupt notifications to detect physical link state changes.
In this scenario, the physical NIC hardware/firmware level failed to register or broadcast the loss of signal interrupt to the ESXi device driver during physical link disconnection. Because the pNIC driver continuously reported Link Status: Up, the ESXi Observation Daemon (vobd) and host daemon (hostd) never generated a vob.net.vmnic.linkstate.down event. Without this event, vCenter Server receives no trigger to raise a network disconnect alarm, and the vSwitch/N-VDS Teaming engine does not initiate failover to secondary uplinks.
The absence of link-down events in both iDRAC and ESXi logs confirms the failure occurred below the hypervisor layer within the pNIC transceiver, physical cabling, or NIC firmware.
Physical Layer Inspection: Inspect, reseat, or replace the SFP/transceiver module and physical network cabling connected to vmnic on the affected host.
Firmware and Driver Update: Verify that the physical NIC firmware and ESXi native driver combination matches the recommended asynchronous version on the VMware Compatibility Guide (VCG), and update them if out of alignment.
Hardware Vendor Diagnostics: If physical re-seating and firmware updates do not resolve unmonitored link drops, engage your server hardware vendor to run diagnostic tests or replace the physical NIC adapter.
Network Failure Detection Enhancement: If you operate in an environment prone to upstream or silent link failure where physical carrier signal remains present, evaluate configuring Beacon Probing on your vSwitch/N-VDS port groups (requires 3 or more teamed uplinks) to detect silent link failures independent of pNIC link status.
For further details regarding pNIC link state behavior and failure detection in vSphere, refer to the following Broadcom Knowledge Base resources:
