/vmfs/volumes/####-#####-####-###########/VM_Name/vmware.logYYYY-MM-DDTHH:MM:SS.###Z| worker-######| I005: DISKLIB-CTK : Could not open change tracking file "/vmfs/volumes/####-#####-####-###########/VM_Name/VM_Name-000001-ctk.vmdk": Change tracking invalid or disk in use.YYYY-MM-DDTHH:MM:SS.###Z| worker-######| I005: DISKLIB-CTK : Change tracking invalid; reinitializing.YYYY-MM-DDTHH:MM:SS.###Z| worker-######| I005: DISKLIB-CTK : Auto blocksize for size ############# is #####.YYYY-MM-DDTHH:MM:SS.###Z| worker-######| I005: OBJLIB-FILEBE : Error creating file '/vmfs/volumes/####-#####-####-###########/VM_Name/VM_Name-000001-ctk.vmdk': 3 (The file already exists).YYYY-MM-DDTHH:MM:SS.###Z| vmx| I005: UTIL: Change file descriptor limit from soft #####,hard ##### to soft #####,hard #####.VMware vSphere ESXi 8.x.
The Power On operation will complete once the CTK is successfully initialized. This might take a long time depending on the storage size of the virtual machine.
If the task is taking a very long time and powering on the VM is critical, perform the following steps to power on the VM immediately:
esxcli command explained in the KB Powering off an unresponsive virtual machine on an ESXi host.esxcli vm process kill -t soft -w WorldID
