Component removal for VCF Automation failed while executing the steps from KB 'Failed component cleanup during VCF 9.1 installation or upgrade'
Article ID: 451851
VCF Automation VMware vSphere ESXi
- Failed to remove VCFA component refer to KB Failed component cleanup during VCF 9.1 installation or upgrade and below error report in lifecycle task:
"Unable to unregister components from VCF Operations"
- Workload pods entered ImagePullBackOff because local registry endpoint ###.##.###.##:5000 refused connections.
"curl: (7) Failed to connect to ###.##.###.## port 5000 after 0 ms: Could not connect to server"
- Inspection of namespace vmsp-platform showed zot-1 and zot-2 in 0/1 READY state
- Describing the zot pods revealed volume attachment failures within the vSphere CSI driver interface.
"attachdetach-controller AttachVolume.Attach failed for volume "pvc-xxxxxxxxxxxxxx": timed out waiting for external-attacher of csi.vsphere.vmware.com CSI driver to attach volume"
VCF Automation 9.1
Unconsolidated virtual machine snapshots on the VCFA appliance locked the virtual disk chain, preventing the vSphere CSI driver from attaching persistent volumes to the Zot image registry pods (zot-1, zot-2)
1.Delete all active snapshots on the VCFA virtual machine via vCenter Server to consolidate the VMDK disk chain.
2.Confirm volume attachment completes and verify zot-1 and zot-2 pods transition to 1/1 Running state in namespace vmsp-platform.
kubectl get pods -n vmsp-platform -l app.kubernetes.io/name=zot -w
3.Clear all stale pending and queued tasks in the vmsp-platform namespace.
kubectl delete task -n vmsp-platform --all
4.Verify that all VCFA application pods return to Running status
kubectl get pods -A | grep -vE 'Running|Completed'
5.Re-execute the VCFA component removal workflow per KB: Failed component cleanup during VCF 9.1 installation or upgrade.
