Edge node passwords and/or edge node inventory showing out of sync or showing as disconnected in SDDC manager.
This could be caused because the edge node VM was torn down and re-created on a different cluster outside of the SDDC manager.
To resolve this issue the edge node needs to be torn down and re-created from the SDDC Manager directly
migrate_edge_node to the /home/vcf/ directory on the SDDC Manager.python3 migrate_edge_node.py \ --target-cluster <name-or-uuid> \ [--force] \ <sso_user> <sso_pass> \ <nsx_mgr_fqdn> <nsx_user> <nsx_pass> \ <edge_fqdn> <root_pass> [admin_pass] [audit_pass]
