- VCF Fleet Management UI is blank
- VMSP nodes failed to uncordon automatically after a planned restart and VMSP nodes report a Ready, SchedulingDisabled status
- Run vcf_services_runtime_shutdown.sh script failed due to "Timed out waiting for task xxx after 600s"
- Manual inspection confirmed the shutdown task was still registered as "Running" despite the script termination.
VCF Operations 9.1
