Virtual machines fail to power on or migrate, and the environment reports that no compatible host is available.
Article ID: 448057
VMware vSphere ESXi
  • The vSphere Client returns the error: No host is compatible with the virtual machine. The user specified host is not compatible.
  • The iSCSI software adapter (e.g., vmhba68) shows no active paths or targets.
  • vmkping from the iSCSI VMkernel port (e.g., vmk2) to the storage processor's IP fails.
  • The /var/log/vmkernel.log or /var/log/hostd.log contains the following entry: ALERT: Login to iSCSI target iqn.####.com.#### on vmhba68 @ vmk2 failed. The iSCSI initiator could not establish a network connection to the target.
VMware vSphere ESXi
This issue occurs when a physical layer failure or an environmental network blockage disrupts the specific iSCSI communication path. Common causes include:
  • A faulty physical switch port connected to the ESXi host's iSCSI uplink.
  • A damaged network cable.
  • Physical switch configuration errors (e.g., VLAN mismatch or port security blocking traffic).
  • Guest Operating System network configuration errors that prevent the virtual machine from accessing required storage resources.
Follow the steps below to identify and resolve the connectivity failure:
  1. Inspect the Physical Layer: Check the physical switch ports associated with the ESXi host's iSCSI uplinks. Identify any "Link Down" states, CRC errors, or port flaps on the switch side.
  2. Remediate Hardware: Replace the network cable or migrate the connection to a known working physical switch port.
  3. Verify Switch Configuration: Ensure the physical switch port is configured for the correct VLAN and that MTU settings (e.g., 9000 for Jumbo Frames) are consistent end-to-end.
  4. Rectify Guest OS Settings: Verify that the Guest OS has not introduced network conflicts or routing changes that prevent it from communicating with the mapped storage resources.
  5. Rescan Storage:
    • Log in to the vSphere Client.
    • Select the affected ESXi host.
    • Navigate to Configure > Storage Adapters.
    • Select the iSCSI software adapter and click Rescan Storage.
  6. Verify Path Health: Navigate to Storage Devices > Paths and ensure all paths for the LUNs are listed as Active or Active (I/O).
Datastores and devices are not visible on certain ESXi hosts.
