After upgrading to ITCM 14.6.0, users are unable to save specific Remote Control settings as defaults through the Viewer GUI. Specifically, when selecting Experience > Color Reduction > TV Color: 6 bits/pixel and clicking "Save as Defaults," the setting is not persisted. Subsequent connections revert to the previous or system-default color depth.
Impact: Higher color depths on certain network or hardware configurations can cause the target computer's display to turn black for several seconds, leading to user confusion or accidental shutdowns.
Product: CA Client Automation / IT Client Manager
Version: 14.6.0, 14.5 CU7
Component: Remote Control Viewer
To force the 6-bit color depth default, the configuration must be set manually via the command line for each affected user profile on the machine where the Remote Control Viewer or DSM Explorer is hosted.
Note: Since this is a CURRENT_USER attribute, this command must be executed for every user account that utilizes the Remote Control Viewer on that specific workstation.
