After upgrading to DX UIM 23.4 CU6, the prediction_engine.QOS_MESSAGE queue grows rapidly and does not drain. This typically occurs in environments with high QoS volume or where Time-To-Threshold (TTT) is configured.
prediction_engine.QOS_MESSAGE queue turns yellow in the Hub GUI.prediction_engine.log repeatedly shows: INFO calculator.DataGathererImpl - TTT definition not found in memory, attempting to reload from file for metric: ####hub.log contains errors failing to open .sds files for the prediction engine queue.prediction_engine probe.prediction_engine probe 23.4.6A defect in the prediction_engine causes repeated attempts to reload TTT definitions, overwhelming the queue processing. Additionally, default Java memory settings for the probe may be insufficient for high-volume environments.
Increase the memory allocation for both baseline_engine and prediction_engine to prevent performance degradation.
setup section.java_mem_init: 2048mjava_mem_max: 4096mprediction_engine-23.4.6-defect-DE661563_test_fix patch. (attached to this KB)
For additional information Contact Support - Support Portal - Broadcom support portal
For defects and enhancements, subscribe to this article to be updated on fix status. Subscribe to a Broadcom knowledge article by article or product
