After updating a date field, if you attempt to double click it again, and click on the box in the lower right corner, all rows of the date value may get updated
Steps to Reproduce:
1. Open any grid within the MUX, for example, the Project list
2. Update a date field, for example Start Date
3. Click off the field to ensure the value is applied
4. Click back on the field, and double click the square in the lower right corner
Expected Results: Nothing in particular is expected to happen
Actual Results: All rows of the Start Date field are updated to the same value that was double clicked.
Workaround: None
Clarity 16.4.2
DE208285
Resolved in Clarity 16.4.3.
