Flow metrics stop collecting for NSX-T Edge Nodes in VCF Operations for Networks
Article ID: 445408
  • Flow data for specific NSX-T Edge nodes or Transport nodes is missing from the VCF Operations for Networks (formerly Aria Operations for Networks) UI.
  • The NSX-T data source shows a "Green" or "Success" status, but recent flow metrics are unavailable.
  • Running the UI search query NSX-T Transport Node where Vendor ID is set returns  all the entities and then filtered by Edge to identify the specific NSX-T Edge nodes or Transport nodes not in inventory.
  • In the Collector logs (/var/log/arkin/collector/collector.STDOUT), you see indications that inventory tasks are starting but not completing.
VCF Operations for Networks 9.0.x
This issue is typically caused by a thread-locking condition within the Collector's inventory synchronization service. When the nsxt.TransportNode.inventory task becomes thread-locked, the appliance cannot complete the mapping of incoming IPFIX (UDP 2055) flow packets to the corresponding inventory objects.
To resolve this issue, you must force a refresh of the inventory synchronization to clear the locked threads.
Step 1: Verify Connectivity
Before performing a reset, ensure that flows are reaching the collector:
  1. Log into the Collector CLI via SSH.
  2. Run a tcpdump to verify incoming IPFIX traffic:
    tcpdump -i eth0 port 2055
Step 2: Toggle Data Collection
If packets are arriving but not displaying:
  1. Navigate to Settings > Accounts and Data Sources.
  2. Locate the affected NSX-T Manager data source.
  3. Click the Edit icon and toggle the collection status to Disabled/Off.
  4. Wait for approximately 5–10 minutes to allow existing threads to time out and clear.
  5. Toggle the collection status back to Enabled/On.
  6. Wait 15–30 minutes for the inventory sync to complete and flows to begin appearing.
Step 3: Collect Debug Data (If Issue Persists)
If the flows stop again after a period of time:
  1. Do not reboot the appliance or restart services immediately.
  2. Generate a  Thread Dumps from the collector node. See command below:
    jps -l (identify the collectorMain process id from this command)
    jstack -l <PROCESS_ID>  >& jst.output
    See steps below:
    ubuntu@aria-networks-collector :~ $ jps -l
    3409 /home/ubuntu/build-target/launcher/launcher-0.001-SNAPSHOT.jar
    3170 com.vnera. latency. NetopaCollector
    10308 com. vnera.collector.CollectorMain
    2998 com.vnera.telemetry.SwitchTelemetryServer
    21064 jdk.jcmd/sun.tools.jps.Jps
    4425 com.vnera.ipfix. IpfixProcessor
    3007 com.vnera.telemetry.NSXMetricServer
    ubuntu@aria-networks-collector :~ $ jstack -l 10308 >& jst.output
  3. Move the generated jst.output file to /home/support/ from /home/ubuntu
    See commands below:
    ubuntu@aria-networks-collector:~$ sudo cp jst.output /home/support/
    ubuntu@aria-networks-collector:~$ exit
    logout
    support@aria-networks-collector:~$ ls -lrth
    total 188K
    -rw-r----- 1 root root 185K Jun 23 21:20 jst.output
    support@aria-networks-collector:~$ sudo chown support:support jst.output
    total 188K
    -rw-r----- 1 support support 185K Jun 23 21:20 jst.output
  4. Winscp the above file to local system
  5. Generate support bundle for the collector in question
  6. Open a support case with Broadcom Support using the directions at KB 142884 - Creating and managing Broadcom cases to review support bundle and thread dump
