BFD tunnels between Edge nodes on same cluster remained down after a power outage
Article ID: 444632
VMware NSX VMware Telco Cloud Automation
After recovering from a power outage, some of the control plane nodes and worker nodes were not reachable with each other which resulted in TCA cluster instability.
Issue from TCA is external IP was not getting assigned to the newly created node
The tier-1 and tier-0 gateways for some of the segments which assigns DHCP IPs to control plane nodes and worker nodes are deployed on these edge nodes.
NSX 4.2.1.4
TCA 2.3
The control plane and worker nodes receive DHCP IP address from the DHCP server configured on the segment which are deployed on the tier1 routers.
These tier1 routers are deployed on the Edge nodes where BFD/TEP tunnels remained down after power outage.
Migrate/vmotion NSX edge nodes to different ESXi hosts and ensure the BFD/TEP tunnels comes up between NSX edge nodes and also with ESXi hosts
Make sure the DHCP IP address is assigned to the control plane and worker nodes and they are able to reach each other and the cluster becomes stable.
Refer KB KB 419021 for more information
