During authentication flows in the Symantec Identity Security Platform (IDSP) 4.0, the Authentication Manager Service calls the internal iarisk microservice to evaluate a contextual risk score for the authenticating user. When the iarisk service does not respond within the configured timeout window, the platform catches an IARiskException (Error Code 8800014) and applies a safe-fail default risk score of 100 — the highest possible value — for that authentication attempt.
Environments experiencing 15–20 of these errors per hour will see a corresponding number of artificially elevated risk scores in their risk reporting data.
The error is a network I/O read timeout on the internal Kubernetes POST request to /iarisk/v1/UserRiskScoreEvaluator.
| Parameter | Platform Default | Tuning Guidance |
| riskRequestTimeoutMillis | 60,000 ms | Set proportional to your environment's observed iarisk response time. A value significantly lower than the default reduces the delay before fallback triggers on a slow or unresponsive service. |
| minimumNumberOfCalls | 1,000 | Set to a value reachable within your environment's normal call volume so the circuit breaker can evaluate failure rate. Environments with low authentication throughput need a lower value. |
| slidingWindowSize | 1,000 | Should be proportional to minimumNumberOfCalls and your expected call rate. A window too large relative to call volume will delay circuit breaker reaction. |
| failureRateThreshold | 50% | Lowering this makes the circuit breaker more sensitive to partial degradation. Adjust carefully — too low a value can cause the circuit to open on transient blips. |
| waitDurationInOpenStateMillis | 1,000 ms | Set to give the iarisk service enough time to stabilize before the circuit transitions to half-open and resumes probe calls. Too short a value causes premature retry storms. |
