During a VMware Cloud Foundation (VCF) workload domain upgrade, Configure for VMware NSX Edge Cluster Upgrade and NSX Upgrade Finalize options are greyed out in the VCF Operations console. This issue typically occurs because NSX Edge component details are missing from the SDDC Manager's Platform database, often due to Edge nodes being deployed directly on NSX (out-of-band) rather than through SDDC Manager.
The VCF Operations Platform database lacks current Edge inventory data and reflects a stale NSX-T version. This database desynchronization prevents the lifecycle management workflow from validating the management plane upgrade state and enabling the Edge finalization workflow.
