When testing the database connection in the `data_engine` probe, the connection fails with the following error, even though logs may indicate that some operations (like OQS record inserts) are successful.
**Error Message:**(1) Open [Microsoft OLE DB Driver for SQL Server] Invalid connection string attributeCOM Error [0x80004005] Unspecified error - [Microsoft OLE DB Driver for SQL Server] Invalid connection string attribute
UIM Version: 23.4.x
Database: Microsoft SQL Server 2022
Database Configuration: Always On Availability Groups (AOAG) with Encryption enabled.
Driver: Microsoft OLE DB Driver for SQL Server (v18.x or higher).
The Microsoft OLE DB Driver for SQL Server (v18+) reports an "Invalid connection string attribute" when there is a conflict between the Integrated Security=SSPI parameter and the credentials (User ID/Password) provided in the standard data_engine configuration fields.
To fix this issue, clear the credentials and setting the connection parameters as follows:
1. Deactivate the data_engine probe in the Admin Console or Infrastructure Manager.
2. Open the data_engine configuration.
A. Delete any values in the User ID and Password fields so they’re completely blank.
B. Update the parameters: In Raw Configure, go to the setup section, find the parameters key, and set it to: Language=us_english;Integrated Security=SSPI;
(Make sure there are no other conflicting security attributes in the string).
3. Activate the data_engine probe back on.
4 Click Test Connection — it should now show “Connection successful.”
