We want to use the upgrade tab to upgrade Workload Automation System Agent to 24.1 on the Linux server.
It failed to add setup.bin file on the Add Installer tab on WLA Agent Manager
Error: org.apache.tomcat.util.http.fileupload.impl.SizeLimit.ExceededException: the request was rejected because its size (390303334) exceeds the configuration maximum (314572800)
Error received on WLA Agent Manager v1.0.02
Upgrade to WLA Agent Manager 1.0.04 or higher (This issue is corrected in version 1.0.04 and higher)
or
Specify the following in your WAMPROP member:
spring.servlet.multipart.max-file-size=1GB
spring.servlet.multipart.max-request-size=1GB
