You need to identify the specific regular expression (regex) engine utilized by CA Test Data Manager (TDM) to ensure consistent results when automating masking configurations or testing external tools outside of the TDM portal.
TDM docker portal 4.11.x
CA Test Data Manager uses Java's native regex engine for all portal-based regex operations.
