"IP address pool 'management-global-ip-pool' is exhausted. Total: X, Used: X, Free: 0. No available IP addresses for new nodes. Expand the IP pool for the VCF services runtime using the 'Expand Node IP Pool' action menu."
Error ID: com.vmware.vcfms.infrastructure.ipam.PoolExhausted
VCF Services Runtime 9.1
Provided IP pool does not have enough number of IPs to allocate to more nodes.
vmware-system-user and provide the password for the account.vmware-system-user the password).sudo -ichmod +x ip-pool-update.sh./ip-pool-update.sh <ipv4_list> [ipv6_list]
Script usage:
Usage: ../../../../vmsp/scripts/manual-kb/ip-pool-update.sh <ipv4_list> [ipv6_list]
Arguments: ipv4_list Comma-separated IPs, ranges, and/or CIDRs for ipPool. ipv6_list Optional; same for ipPoolv6. Omit to leave ipPoolv6 unchanged.
Nodes will be provisioned and all machines will be in running phasekubectl get machine -ANAMESPACE NAME CLUSTER NODE NAME READY AVAILABLE UP-TO-DATE PHASE AGE VERSIONvmsp-platform management-default-{UNIQUE_ID} management management-default-{UNIQUE_ID} True True True Running 3h57m v1.34.2vmsp-platform management-default-{UNIQUE_ID} management management-default-{UNIQUE_ID} True True True Running 14m v1.34.2vmsp-platform management-default-{UNIQUE_ID} management management-default-{UNIQUE_ID} True True True Running 3h57m v1.34.2vmsp-platform management-default-{UNIQUE_ID} management management-default-{UNIQUE_ID} True True True Running 3h57m v1.34.2vmsp-platform management-{UNIQUE_ID} management management-{UNIQUE_ID} True True True Running 3h57m v1.34.2
