Problem: Job stuck in Ready to Start status in Automation Engine workflow
Article ID: 439633
CA Automic Workload Automation - Automation Engine
A job within a workflow remains in "Ready to Start" status in the Automic Web Interface (AWI) and workflow monitor, even though execution details and agent logs confirm the job has already finished with an "Ended OK" status․​​​​‌
Symptoms
  • Job status is Ready to Start in UI
  • Subsequent jobs in the workflow must be started manually
  • Agent logs show normal completion
This occurs intermittently when a job changes its Queue dynamically within a workflow precondition․
Component: Automation Engine 24․4․3
DE185122. This is a problem found when a queue switch happens in preconditions while jobs are waiting for queue slots and large variables are present. When this condition occurs a database flag is set to null which prevents the UI from receiving status updates during execution․
Workaround/Solution
Remove the Queue assignment from the workflow Condition (Preconditions) and move it to the task Pre-process tab․
