When an ESXi host is rebooted or powered on, virtual machines configured under the Manual Startup section of the VM Startup/Shutdown settings do not automatically power on, even if they were in a powered-off state prior to the host reboot
VMware ESXi 7.x/8.x
VMware vCenter Server 7.x/8.x
The VM Startup/Shutdown feature is designed to automate the power state of virtual machines based on their specific placement in the configuration list:
- Kindly refer this KB article before executing the below steps -- https://knowledge.broadcom.com/external/article?articleNumber=390139
- To ensure a virtual machine doesn't powers on when the ESXi host reboots, it must be moved from the Automatic Startup section to Manual Startup.
Steps to Modify Startup Behavior
- Sample snippets:
1.Test was performed on esxi host "192.###.###.152" by placing both VM's in powered OFF state.
2. Both VM's placed under "VM Startup/Shutdown" option.
VM name -- Web01
VM name -- DB01
- Rebooted the esxi host and the uptime is 70 seconds.
- The VM "Web01" was automatically powered ON after the host was rebooted and not the other vm "DB01" which was set to "Manual Startup" option.
- Validated the uptime from "Web01" vm CLI.
- vCenter 8.0.2 UI: If you encounter overlapping labels in the Edit dialog, this is a known issue resolved in vCenter 8.0 Update 3g Overlapped labels fix.
