There are some problems in SD Jobs options settings :
Client Automation 14.6
Open a case at Broadcom technical Support and request the fix T533413
This fix delivers the file gui_sd.dll
Size : 1 963 904 bytes
Date : 14 April 2026
Version : 14.6.0.105
Install this fix on the Domain Manager and Remote DSM Explorer 14.6
