The locator LED command does not work for the Dell HBA345 Adapter
Article ID: 436143
VMware vSphere ESXi VMware Cloud Foundation
  • The command "esxcli storage core device set --led-state=locator -d naa.xxx" is used to turn on the disk LED on VCF Operations
  • When using the command with disks connected to the Dell HBA345 Adapter, the LED blinking function only operates successfully on the initial attempt.
  • Subsequent attempts to run the command will not cause the LED to blink.
  • VCF Operations 9.x
  • VMware ESX 9.x
  • This issue is related to the adapter firmware
  • Older firmware package versions 11.08.08.00 to 11.15.26.00 work as expected.
  • Newer firmware versions report this issue
Please contact Dell Support to further investigate the issue
